SL55/63/65/R230 AMG: ABC Sport... Or not?
Old Jan 14, 2005 | 07:53 PM
sprins's Avatar
G55, SLS, smart eq
Question ABC Sport... Or not?
Hi,
I was wondering if I'm the only one that thinks there is little (if any) difference between the feel of the SL55 with the ABC Sport setting on or off. I've been drinving my car for approx 3000Km now and every now and then I drive with this setting on and off, but I don't feel a difference. On my 500SL (R129) I inmediately feel the difference between the sport/regular setting so I wondered why it isn't so apparent on the SL55.
I couldn't find any references to this subject in previous threads in this forum
Old Jan 14, 2005 | 09:15 PM
awiner's Avatar
2003 CL55 AMG
The ABC sport setting does not change the suspension feel as far as the dampening rates. It simply changes the rate at which body roll is countered.
Arno Rohringer, head of Mercedes spring/shock absorber development, says body roll during cornering is reduced by 68% and by 75% if the driver has selected ABC's "sport" mode. Braking dive and acceleration "squat" is all but eliminated. Body stabilizing time after a rapid swerve is cut by 30%. Ride height also can be continually adjusted, and at 140 mph (225 km/h) the ride height is lowered by almost a half-inch (10 mm).
Old Jan 15, 2005 | 05:58 AM
sprins's Avatar
G55, SLS, smart eq
Thanks for clearing that up. So basically the ABC system reacts faster and more with Sport mode on.
Is there a downside to constantly drive with Sport mode on? Are the hydraulics stressed significantly more or doesn't it realy matter? If it doesn't really matter I don't quite understand the option to turn it explicitly on/off as the syspension feel is not affected, and it makes the car handle better.
Old Jan 15, 2005 | 11:56 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
I pretty much drive only in the sport mode. The times that I have used it in the reg mode I have noticed increased body roll.
Old Jan 15, 2005 | 12:25 PM
awiner's Avatar
2003 CL55 AMG
You may use Sport mode all the time. Nothing wear wise is different between Sport mode on and off.
Old Jan 15, 2005 | 12:38 PM
moa4r's Avatar
S4
if it reduces body roll by that much, wouldn't you feel a difference with it on/off?
Old Jan 15, 2005 | 12:53 PM
sprins's Avatar
G55, SLS, smart eq
Perhaps that would depend on the driving-style.
I wondered because on my 500SL I actually feel the difference of sport vs. normal in my butt and in the steering wheel inmediately, because the suspension is simply stiffened (non intelligent ABC I guess).
I guess that, as IngenereAMG said, driving with sport-mode on all the time would make it more apparent if you occasionally turn it off. That and the driving style of course
As per awiners advise I'll turn it on and leave it on.
Old Jan 15, 2005 | 04:00 PM
vraa's Avatar
SL500 here and it's on 24/7.
Old Jan 15, 2005 | 05:15 PM
MB AMG's Avatar
2002 E55 AMG
Any info on the old ADS suspension system?
Old Jan 16, 2005 | 12:59 PM
Maff's Avatar
Must admit going from CL500 to CL55 I noticed quite a difference. The CL500 rolled quite a bit without ABC switched on, however on the 55 the body roll without ABC is much less than the 500. I really only notice the improvement ABC makes when corning very hard in the 55, where I used to have ABC switched on in the 500 just to go round normal corners!
Hope that makes sense!
Old Jan 16, 2005 | 01:08 PM
blueSL's Avatar
SL55 AMG
I had ADS in my old SL600 and it was a very basic forerunner of ABC. It was standard in the SL600 because the car would otherwise exhibit excessive nose-heavy behaviour with the V12 lump up front. ADS (adaptive damping system), as its name suggests, only altered the damping characteristics to reduce roll, dive and squat. As such, its ability to adjust the suspension was pretty limited.
ABC is a huge step forwards because it also changes the effective characteristics of the springs as well by changing their effective length. This gives ABC a two dimensional matrix for controlling the car's suspension and makes the cornering of the car much more neutral, a great disguise of its considerable bulk.
For me, ABC is the triumph of the SL and makes the car a much more sporting drive than it would otherwise be.
Old Jan 16, 2005 | 01:20 PM
sprins's Avatar
G55, SLS, smart eq
I totally agree. For such a heavy car it feels very light and nimble to drive. Much more than e.g. the (lighter) R129 series.
Old Jan 16, 2005 | 03:29 PM
awiner's Avatar
2003 CL55 AMG
Keep in mind the AMG's use different ABC software for more aggressive cornering response.
This is probably why you noticed the difference between the CL500 and CL55.
Old Jan 17, 2005 | 08:52 AM
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
for my the ABC is the best feeling of a SL race car and without is a little more conftable and smooth. you feel less the bump of the street
