SL63 AMG & SL65 AMG (R231) 2012 to 2020 (in US launched as 2013 model) Facelift from 2017
Spacers Anyone?
Old Sep 18, 2016 | 07:33 PM
mellowyellow's Avatar
AMG GT C Roadster
Spacers Anyone?
Anyone put spacers on the OEM forged wheels for the R231?
I think the fronts could use somewhere around 5mm and rears maybe 15mm. These numbers are just a guess, would love to see anyone who has done it with some pics. Probably need longer bolts too.
Old Sep 18, 2016 | 08:15 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
I put them on but only because the wheel needed 15mm to make 30et
Old Sep 18, 2016 | 10:28 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Check the posts from wolfman on the R231 forum. He has the SL63 wheels with spacers on his SL550. Looks good!
Old Sep 19, 2016 | 11:14 AM
okbarnett's Avatar
you probibly can use 10 all around and they arent the same as the one in your pic. you need flanged hub centric for mercedes and add 10mm for bolts. hr makes the set or you can buy everything on ebay cheaper
Old Apr 17, 2018 | 09:28 AM
AMG GT C Roadster
Re-upping this thread since I finally got around to ordering and installing the spacers on the back. It looks sooooooo much better.
Wolfman's posts were definitely very helpful, thanks.
I went with 12mm in the back and it's perfect. I agreed with Wolfman and others that 20mm was too much in the rear. I did H&R spacers and H&R bolts.
I will be putting 5mm on the fronts, and then it will be perfect all the way around.
Old Sep 21, 2018 | 02:21 AM
Riverflyer's Avatar
TT 512 BB Ferrari, Dinan Z8,997 GT3, 74 BMW 3.0CSI
Where are the pics mellow??
Old Feb 10, 2022 | 09:02 PM
litumup411's Avatar
2021 AMG GT BS 2008 CLK63 BS 2011 AMG SLS
Installed spacers on my SL63 earlier this week. Went with 10mm up front and 15mm out back. Certainly could be more aggressive, but didn't want to have the tires extend beyond the wheel wells..The goal was for it to look a little more aggressive without significantly changing the driving dynamics.
Before: you can see the tires seem almost inboard
Before
After: tried to get the same angle
After: really happy with how it turned out.
Old Feb 11, 2022 | 12:19 PM
okbarnett's Avatar
you are likely to scrape on the fenders
Old Feb 11, 2022 | 01:04 PM
litumup411's Avatar
That was certainly a consideration and the reason that I went very conservative with the spacers. I’ve driven the car over 500 miles and no concerns even over Philadelphia potholes.
Whike it might look like the tires extend past the fenders, the outer most inside of the tire is actually even with the top of the wheel wells
