SL63 AMG & SL65 AMG (R231) 2012 to 2020 (in US launched as 2013 model) Facelift from 2017
What air pressure are you running in SL63?
Old Jul 25, 2019 | 01:36 PM
AFRJacket's Avatar
SL 63 AMG
Door states 46 front/48 rear psi, but I think that's too high for routine driving. What suits you best? Air Pressure notice just came on and this is the first time I'll need to inflate them. Thx!
Old Jul 25, 2019 | 03:21 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
I have a 2017 SL65 but the pressures should be similar. There are four choices depending on load and maximum planned speed. Not over 155 with 2 passengers is 35F/33R, with maximum load it is 36F/36R. If you plan on diving at 186mph it is 44F/42R with 2 passengers, 48F/46R with maximum vehicle load. The sticker is on the gas filler cap.
After some experimentation I settled on 39F/36R for more responsive steering with good ride quality. But that is with the V12 up front.
Old Jul 26, 2019 | 09:22 AM
AFRJacket's Avatar
SL 63 AMG
Great; thx! It's strange they'd list it like they do inside the door; just creates confusion. I'm going to start by trying 37/35 due to tires not being cold when I get the air. 'preciate it, and nice ride btw!!!
Old Jul 26, 2019 | 03:09 PM
Quadrobenz's Avatar
Sorry about the typo above. I meant to say SL65. I do also have an S65, that gets 45psi in the front tires.
Let us know what pressures you end up liking in your SL63.
Old Aug 1, 2019 | 02:22 PM
AFRJacket's Avatar
SL 63 AMG
Turns out I have a bad tire pressure monitor. Air pressure was at 44 on all tires. Once I confirmed this is a maintenance item (bad sensor), I lowered all 4 tires to 40. It was running hard over bumps and now I know why.
Old Aug 1, 2019 | 05:48 PM
Quadrobenz's Avatar
44psi all around would be harsh in normal driving. Too bad about the bad pressure monitor. Since you are using the in-car monitor for the pressures they are usually accurate but will not measure the tires cold as you pointed out. I have a compressor in my garage and several accurate gauges so all my readings are cold in the morning after sitting all night. Suggest you drop the rear tires a couple of psi. The car will ride better and handle slightly more neutral. I hope you find the ride more reasonable now.
Old Aug 2, 2019 | 09:43 AM
AFRJacket's Avatar
SL 63 AMG
Thx. Will try that once I get the bad sensor fixed/replaced.
