SL63 AMG & SL65 AMG (R231) 2012 to 2020 (in US launched as 2013 model) Facelift from 2017
Front seat configurations
Old May 28, 2021 | 07:52 AM
needs new tyres's Avatar
SL63 W231
I'm slowly working through all the functionality in my new car (2014 R231) & can't figure out how to save the lumber & side bolster settings;
Activate the menu
Select the seat (Driver)
Adjust the lumber support up & out using the dial & display menu - can save, defaults back to no change
Adjust the side bolsters using the dial & display menu- can't save and defaults back to no change
I've tried with the ignition in 2 positions, engine on & off, can't find anything on YouTube
Any help, support would be awesome
Cheers
Tyrone
Old May 30, 2021 | 03:37 PM
PlayersClubWheels's Avatar
Former Vendor of MBWorld
Mercedes-Benz
Activate the menu
Cheers
Tyrone
Hi Tyrone,
Congratulations on your new SL! Here's a link that shows you how to set your memory seats. https://www.mboffremont.com/how-to-s...-memory-seats/
Eddie
Old May 30, 2021 | 03:48 PM
andy-gts's Avatar
sl63 amg
yes that sets the seat memory and mirror position, but I'm with you, too bad you cant save the massage setting , i would love to have it on all the time !!
Old Jun 26, 2021 | 02:58 PM
rorywquin's Avatar
Shanks’s Pony
From my owners guide - seems there is no “store” function. Set your choices and “return” out of the current menu.
Selecting the adjustment function and seat
Press the button.
or
To select Vehicle from the main function bar: turn and press the controller.
  • The vehicle menu appears.
To select Seat settings : turn and press the controller.
  • The menu for the seat settings appears.
or
Press the button on the controller.
  • The menu for the seat setting appears.
To select the desired seat function: turn the controller and press to confirm.
To switch between Driver and Front passenger : slide the controller.
Adjustment functions
Setting the backrest side bolsters
Call up the seat functions more.
To select Backrest sides : turn and press the controller.
To select a seat: slide the controller.
To change the setting: turn the controller.
  • The change can be seen in the settings display.
To exit the menu: press the button.
Adjusting the seat contour in the lumbar region of the seat backrest
This function allows you to adjust the air cushions in the lumbar region of the backrest (4-way lumbar support).
To select Lumbar : turn and press the controller.
To activate the setting element: press the controller.
To change the setting: slide or the controller.
  • The change will be visible in the setting element.
Adjusting the seat cushion
To select Seat surface : turn and press the controller.
Setting the driving dynamics
To select Dynamic seat : turn and press the controller.
You can select:
  • OFF :
  • 1 : Level 1 (weak)
  • 2 : Level 2 (strong)
To select the setting: turn the controller.
Massage programs
Overview
You can select the following massage programs:
  • Relaxing Massage
    Massage the entire back, rising waves, soothing downward movements
  • Activating Massage
    Mobilising massage and rising and descending dynamic waves
  • Classic Massage
    Single and twin waves moving upwards across the entire back
  • Mobilizing Massage
    Mobilisation via stronger single and twin waves moving upwards across the entire back
Selecting a massage program
etc
Old Jun 28, 2021 | 11:08 AM
andy-gts's Avatar
sl63 amg
yep no store function but my lumbar and side bolsters stay set where I set them, just the massage doesnt save and I dont have to choose set 1,2,3 on the door to save
