SPrint Booster Issues
Subscribe
Sep 22, 2021 | 09:36 PM
I know this is a long shot, as I already posted this in the r231 forum, but hoping for a hit!
So this week I decided to finally install the Sprint Booster from the 2017 SL550 into the SL63 (also a 2017).
I loved the more responsive feeling of the throttle in the SL550 after adding the Sprint Booster - and while the AMG is much better, it still has a lot to be desired.
After verifying that the module was appropriate for all 2017+ V8 models on the Sprint Booster site, I proceeded to quickly install. Only problem - it doesn’t work at all!
Following installation, I started the car and immediately received multiple error codes (distronic failure, blind spot monitoring inactive, etc) as well as a check engine light, and zero throttle response. ZERO. Press the pedal and nothing happened.
I had read about this happening in a few situations, related to either loose connections, or installing while the keys were still in proximity. So I pulled it out and reassembled without the module - everything returned to normal after 3 full restart cycles (clearing CEL)
After some additional research - I tried three different times in the past 24hrs to install. Leaving the door open more than 15
minites, no keys anywhere near the car, fully powered down, touching no keys interior buttons or switches, fully inspecting each plug and fully securing each connection, and each time with the same result. I even peaked inside the module, to make sure no wires were crimped and no pins were broken. None seen. And each time, once I removed and restarted the car without the module place, all error codes cleared within 3 start cycles.
So what gives? Anyone had similar experience or ideas? I thought about pulling the main fuse or disconnecting the battery and trying one more time - but quickly tiring of remove that damn pedal. . .
Would love any advice any might have.
Reply 0
Sep 25, 2021 | 10:30 PM
I wish I could tell you, sounds like a mess, sorry its happening
Reply 0
Sep 27, 2021 | 11:19 AM
Sorry off topic
Quote: I wish I could tell you, sounds like a mess, sorry its happening
So Andy-GTS I bumped into your name posting here and I remembered you from our old P928 GTS days. Beside my SL55 I have got a 2017 AMG GTS as well and will be taking it to 3rd coast in Marble Falls in November.
You should try and make it there and see some old friends!
Best H
Reply 0
Sep 27, 2021 | 06:30 PM
hmmm I will see if I could get off, you think roger would be ok
Reply 0
Subscribe
Currently Active Users (1)
