Assistance needed
Supposedly needs harness and modules that were under carpet need replaced.
The dash lights up but it wont run.
I`m reasonably mechanically inclined so the work does not scare me too much depending on depth.
Car is in very nice shape and has sub 40k miles.
Do i run away fast or delve further?
Steve
What about in the trunk? Work up a list of items that need replacing and estimate the cost. Do you have physical access to the car to inspect it? I don't think I would consider it without a physical inspection or two.
You could easily spend thousands fixing this car even if you did some of the work yourself. Even a non-flooded SL of that year could require lots of work and expense. There are some relatively expensive parts on the m275 V12 that may need replacement. Also, the ABC suspension often requires significant maintenance when it gets to be that old, regardless of miles.
Unless you have a lot of experience with SLs, I suggest walking away from this one.
