SL63 AMG & SL65 AMG (R231) 2012 to 2020 (in US launched as 2013 model) Facelift from 2017
Missing ngine cover star
Old Aug 5, 2024 | 02:05 PM
Bilbo7's Avatar
2015 SL63 AMG (R231)
Well it gone to the black hole where all the other socks go.
Odd the rear mesh was still sitting on the engine cover but the Star has gone, it was there in the Spring but later when checking the oil I thought something looks odd............ next time I realised what
Mercedes, as other have written do not sell the badge alone and as many seem to just disappear and the parts said at least £500 for the whole thing it is a great money spinner for Mercedes
As I still have that rear silver mesh what other Mercedes model engine cover has that Star its about 75mm diameter?
Then maybe I can remove it and fit it to the cover I have as second hand covers are not expensive but cannot find a R231 engine cover on eBay etc in the UK
It needs replacing as it just spoils the whole engine bay
Must be a market for getting a plastic printer company to make some but I guess Mercedes would have a fainting fit over copy write and you would need one to give them
So what
Old Aug 5, 2024 | 02:13 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Yep...what I did was buy a hood ornament, cut off the circle, polish the bottom of it and glued it in...
Old Aug 6, 2024 | 12:24 PM
Bilbo7's Avatar
Hi Manofmyage
I take it by hood ornament you mean stands up in the air motif like this
https://mercedesgenuineparts.co.uk/p...et-star-chrome
rather than a bonnet badge?
I had wondered about an AMG bonnet badge just to be flashy like this so I could bolt it to the cover
https://mercedesgenuineparts.co.uk/p...go-a0008170408
But I don't know the diameter but can ask
Your solution appeals as I have the mesh....... are they 75mm dia as the old cover badge
MUTTER all I need to now is work out how to edit to original to put the E in *ngine (sigh)
Old Aug 6, 2024 | 02:15 PM
W205C43PFL's Avatar
Some suggest using a wheel hub cap. https://mbworld.org/forums/e-class-w...ml#post8525887
Old Aug 6, 2024 | 07:33 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
ebay
Old May 7, 2025 | 07:31 PM
grane's Avatar
GLK350, SL63 AMG
dealer service circumsion
So what
I had the same problem after my last service. I've taken the beauty covers off so there is less cooking.
Old May 8, 2025 | 05:31 PM
W205C43PFL's Avatar
As an enthusiast, you do want to see the actual engine and not a cover so might not be a bad idea.
Old May 9, 2025 | 09:54 AM
Bilbo7's Avatar
We its more than a fancy bling cover its also a water splash guard a lot of the terminals have the loom sort of the clips and exposed wires and solder. As you could keep goldfish in the headlamps some water defiantly going to get in there
Old May 9, 2025 | 10:59 AM
W205C43PFL's Avatar
It traps a lot of heat though, I do notice on turbo charged models, there is a channel where the cover actually routes air to the turbos: https://mbworld.org/forums/c450-c43-...r-channel.html
Goldfish in head lamps is kind of cool so the unit is still sealed enough so the water doesn't leak out and kill the fish?
Old May 9, 2025 | 11:02 AM
W205C43PFL's Avatar
Pretty cool actually I guess the water entered from the top and it won't drain from the bottom hence why it works: https://www.thesun.co.uk/news/319407...oldfish-in-it/
