SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: How do adjust top?
Old Dec 8, 2005 | 12:52 AM
tiggerfink's Avatar
SL500 and A-CLASS
How do adjust top?
I figure out the how to adjust the height of the driver's side glass. But the window is at the lowest setting. The bolt in the picture adjusts the rear side of the driver’s window.
So how do you adjust the top? Top needs to be a little higher on the driver's side. I need top higher because window is tearing up seals.
Attached Thumbnails How do adjust top?-rip-seal.jpg   How do adjust top?-hight-adjustment-bolt.jpg
