SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: problem with roof
Old Mar 29, 2006 | 01:19 PM
96bmw328ic's Avatar
problem with roof
I bought this car as a salvage and I know I'm expected to have some problems but I was wondering why my roof wont go down.
Yesterday I was raising the roof and it made a weird noise like something cracked. now when i go to lower it then red light blinks quickly. What am I doing wrong?
Old Mar 29, 2006 | 04:43 PM
70chevelle396's Avatar
2001 SLK 320 , 1970 Chevelle SS
Do you have the thing in the trunk pulled out?
Ken
Old Apr 3, 2006 | 08:13 PM
mastermind's Avatar
Roof
Hi,
I had a similar problem once - one of the flat metal guides fixed to the roof that normally slides into a rubber-encased opening on the bottom came loose as one of the two screws holding it in place fell off. I simply re-attached it, problem fixed.
Otherwise, the various microswitches that coordinate the roof actions come to mind. They're known to fail over years.
I suggest to see a dealership, though, if obvious loose parts don't seem to be the cause.
Cheers
Tom
Old May 1, 2006 | 03:52 PM
Gabe's Avatar
SLK 230
Manual
The car manual shows in detail a process to open and close the roof by hand. I would try to follow it and see if there is anything loose, cracking, stuck or obviously wrong before trying the hydraulics again. My roof had a problem like that one day, it just would not open. Dealership fixed it under warranty but it took them two weeks. They claimed that somebody from Germany had to visit the dealership to fix two SLKs with the same problem. They never gave me a straight answer regarding the root cause but they mentioned microswitches a lot.
