SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Slk fog lamps
Old May 24, 2006 | 05:36 PM
El Jeffe's Avatar
Slk fog lamps
It seems on the 2000 slk mercedes has changed the fog lights if you have the sports package. In doing so they shanged the plug. Mercedes does not offer a pig tail for this has anyone out there run across this and what have you done.
Old May 25, 2006 | 09:26 PM
Squishy's Avatar
SLK
You have to elaborate this a bit more, what are you trying to do?
Old May 26, 2006 | 06:04 AM
bazzle's Avatar
Sorry... me no understand
Bazzle
Old May 26, 2006 | 01:40 PM
El Jeffe's Avatar
What they did was change the design of the fog light in doing so the changed the plug on the light assembly. So the existing harness will not fit and there is not a listing for plus parts or a new harness pig tail.
Old May 26, 2006 | 04:52 PM
bazzle's Avatar
But they changed the harness so they worked
Still dont see why its an issue?
Are you trying to upgrade and are having problems?
From memory you can just crimp spade terminals on to the loom to fit either if your loom is damaged or you want to modify.
Bazzle
