SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: speed sensor
Old Oct 13, 2006 | 04:24 PM
wilkoo2's Avatar
speed sensor
where is the speed sensor on the gearbox located?? roof problems and asr light on... 230 slk
Old Oct 13, 2006 | 09:44 PM
DickB's Avatar
'99 SLK 230
Speed sensors are on all four wheels.
Old Oct 14, 2006 | 12:25 AM
Buellwinkle's Avatar
Here's the one on the left front axle. Go to my website's resource page and for the SLK go to Component Locations and look for Vehicle Speed Sensor to see all 4.
Old Oct 19, 2006 | 09:33 PM
WB9AXO's Avatar
'98 SLK230, '84 VF1100S
But where is the "Transmission Speed Sensor" (Code 109)?
Old Oct 20, 2006 | 07:48 PM
Where is that code coming from? A P0109 is a MAP Sensor code. Are you sure it's not a P0709 code, Transmission Range Sensor? Maybe the 7 looks like a 1 to you?
Old Oct 21, 2006 | 11:12 PM
WB9AXO's Avatar
I'm having intermittent transmission trouble:
http://www.benzworld.org/forums/r170...wierdness.html
In a reply, a member with a similar problem said he had a Code 109 from his transmission computer. His dealer replaced the "Transmission speed sensor".
Another member suggested checking the transmission codes:
http://www.whnet.com/4x4/dtc-722-6.txt
"Diagnostic Trouble Codes for the Mercedes-Benz 722.6 Transmission"
"109 Component Y/36n# (speed sensor 3) is sporadiacally faulty"
I'm grasping a straws before I give up and take it to the dealer.
