SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK32 ESP System
Old Dec 5, 2006 | 05:50 PM
rfk142's Avatar
SLK 320/32
SLK32 ESP System
Hi Guys,
Can anyone explain to me if there is a relation between the ESP system and the Kompressor on the SLK32? Does the ESP system have the ability to shut down the kompressor? Here is my situation:
1. With the ESP ON, If you tryo to skid sometimes, the ESP will frantically kick in to try to control the car. After that the kompressor will not work (if I try to step on the gas). I have to turn the car off and then back on, and the kompressor will work again.
2. With the ESP off, nothing will happen and the Kompressor will always work.
Do you think there is a relation?
Just as a background. My car used to be an SLK320, I changed the engine, tranny and diff. and reflased the ECU and the transmission computer (EGS) with appropriate SCNs.
Old Dec 5, 2006 | 05:53 PM
rfk142's Avatar
SLK 320/32
Exclamation follow up
Just as a follow up, I have 18inch 225 in both the rear and front
