SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Pulling the CEL code.
Old Dec 13, 2006 | 12:59 PM
CopperDesigno's Avatar
SLK230
Is there a way to check the CEL codes?
My CEL came on and the car is running in "safe" mode. I would like to pull the code before going to the mechanic.
Old Dec 13, 2006 | 06:08 PM
Buellwinkle's Avatar
Your sure it's not Windows running in Safe Mode? You have choices here, if you want a one time read, many Autozones will scan the codes for free. Frankly, these days, having an OBD2 scanner is a must if you plan on doing any work yourself and they are for the most part cheap but not all work with MBs. I use software and cable from http://www.obd-2.com/ and it's worked well for me over the last few years on all my cars and easily paid for itself many times over.
Old Dec 13, 2006 | 06:14 PM
SLK230
Thanks, being a geek, when a computer cuts parameters and operates in a degraded state to save itself or the machine its attached to is playing it safe.
I Found one scanner for $80, but didn't have the software to translate the code.
Old Dec 15, 2006 | 03:03 PM
bazzle's Avatar
Prob need to clean the MAF.
BAzzle
Old Dec 15, 2006 | 03:14 PM
SLK230
Thanks Bazzle,
I cleaned the MAF at the begining of the summer, I'll clean it again and see if the CEL goes out, or do I need to disconnect the battery to reset the computer?
