SLK/R170: My roof problems thread. -> Pleas help along the way
Here I will post my findings, and I hope that someone would like to help my figuring out whats wrong her.
My OBD readings showed nothing, so I'm working kinda of in the blind here.
This is what I found so far:
When vario roof switch operated is only blinking (like if the luggage cover not closed).
I would say about 1 blink per second.
Except that nothing happens nether when tried closing or opening roof.
I have taken of the plastic covers in the boot, and visually every thing looks ok.
I have started at the Multi-function control module (N10-3), and checked the different switches.
All switches is breaking the minus from the battery, so every reading is done against "+".
Ok, here it is:
I also checked what's coming form the "vario roof switch" (S84) to the N10-3.
Here is the result when the S84 was not operated:
Here is the result when the S84 was operated to open roof:
Here is the result when the S84 was operated to close roof:
