SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Loss of Power - HELP!
Old Nov 11, 2007 | 10:47 PM
robert_in_la's Avatar
SL500 and S60R
My girlfriend has a MY01 320 SLK. We're having a serious problem and I am taking the car in as soon as I can. However I am trying to figure out what's going on.
When the car is running for awhile - or from a cold start - the engine has (looses) all of its power after a dead stop.
After pressing on the accelerator from a dead stop the engine has 0% power then after a full 2-3 sec the engine kicks in and acts normal.
When this happens, we pull over and turn off the engine and wait 1 min. before restarting. After we restart the engine the problem goes away.
This has been going on for nearly 4 days. Just tonight the check engine light is now on.
Has anyone had this happen to them? Any thoughts?
Thanks for the help.
Robert
Old Nov 12, 2007 | 12:17 PM
Buellwinkle's Avatar
That's easy one, what are the codes?
Old Nov 12, 2007 | 01:30 PM
SL500 and S60R
P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction
Is this a DIY job or one for shop?
Old Nov 13, 2007 | 03:33 PM
You can replace the pedal position sensor yourself, can't imagine it's that hard or be very expensive. Check my website resource section for links to Duval Motors for the part and SLK Tech Manual component locator to find where it is. If it's intermittent it could be the connector is loose so check that first. Of course being a mechanic pot, it's going get dirty/corroded internally and there's not much you can do about that.
Old Nov 13, 2007 | 05:03 PM
pojr's Avatar
slk320
I am having the same problem. See Throttle position sensor thread...
Old Nov 13, 2007 | 05:05 PM
pojr's Avatar
slk320
oops see you already did.....sorry.
Old Nov 14, 2007 | 11:59 AM
SL500 and S60R
Well it turns out I need to replace the gas pedal... $149 for the part.
Thanks for all the info.
Robert
