SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Wheel help
Old Jan 28, 2008 | 08:02 PM
slk230tt's Avatar
1999 SLK 230
Wheel help
Does anyone know if 18" amg knock off wheels that came off of a 2006 Mercedes Benz E350 will fit my SLK 230 base car? The specs on the wheels are as follows:
Bolt pattern: 5 x 112 mm
Front Wheels: 18 x 8
Rear Wheels: 18 x 9
offset front: 21mm
offset rear: 32mm
Also if these will fit, what tires would work you guys recommend.
Any help would be GREATLY appreciated!
Thanks!
Old Jan 29, 2008 | 04:11 AM
bazzle's Avatar
Not enough front offset , need 30 to 35 from memory.
Wheels bolts wrong size also.
Check tireracks web page for fitments.
http://www.tirerack.com/
Bazzle
