SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Tire and Wheels that WILL fit
Old Feb 20, 2008 | 09:41 PM
slk230tt's Avatar
1999 SLK 230
Tires and Wheels that WILL fit
I just put Chrome Monoblock wheels on my car and they look great . Wheel and Tire sizes are as follows: 18" wheels with a 30 offset -- 265/35/18 on the rear -- 235/40/18 on the front. Had to use 1/4" spacers on the rear, but the front bolted right on. I have NO rubbing at any point. Just though I would pass this info on being when I searched this site for tire fitment, I found nothing in reference to these tire sizes being used. Hope this helps someone else who might be looking for the same info!
Thanks!
Old Feb 21, 2008 | 02:10 PM
bazzle's Avatar
You may get problems later as back tyres wear down (assuming front wear slower) due to the diameter difference. Thats one reason chaps use 225 on front.
http://www.miata.net/garage/tirecalc.html
ABS, cruise and asr, etc all "may" bring a code and put you in limp mode. Hope it works out
Bazzle
Old Feb 21, 2008 | 07:31 PM
slk230tt's Avatar
1999 SLK 230
Bazzle,
I appreciate your input! So far so good...nothing "strange" or "erratic" as you had mentioned in your reply such as...
"ABS, cruise and asr, etc all "may" bring a code and put you in limp mode."
so until I see different...this seem to work out fine and it looks GREAT!
thanks.
Old Feb 23, 2008 | 06:16 AM
bazzle's Avatar
My bad... Im sure you had 255/35/18 but I now see its 265/35/18 rear... oops.
http://www.alloywheelsdirect.net/inf.../mercedes-benz
Bazzle
