SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Strange Noise at Passenger Foot Well
Old Dec 4, 2008 | 11:23 PM
Fingerz's Avatar
slk 230 kompressor
I have a 1999 SLK230 Kompressor with 90K miles. I am getting a very annoying high pitched 1000 HZ noise coming from under the glove box. It happens only when the engine is running and the fan switch is turned off. It comes and goes but will stop if I turn the fan switch on to any speed. I removed the kick panel under the glove box and took off all the cables to the fan and other connectors I found and even removed the air filters. The noise would not stop. It may even be coming from above the fan but it is hard to determine lying unside down with a flashlight.
Any idea what else is under there or what can be causing the noise?
Old Dec 11, 2008 | 12:35 PM
bazzle's Avatar
Remove fan and check for debris. easy job. Drops out from underneath.
Bazzle
Old Dec 15, 2008 | 08:46 PM
Fingerz's Avatar
slk 230 kompressor
Thanks for the suggestion but the noise STOPS when the fan is ON at any speed. The noise is heard only when the fan is OFF.
I doubt there is anything behind the fan that could be causing a sound similar to a steady test tone or a house alarm keypad armed tone.
