SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 2001 SLK 320 Radio shorts out
Old Apr 13, 2009 | 08:23 PM
msqboxer's Avatar
2001 SLK 320
My 320's radio occasional will have no power after starting the car. If I go the the fuse box panel under the hood and pull out the (5) and (8) fuses they are fine. When I put them back in and start the car the radio asks for the code which I enter and it then works again. This situation happens all the time........does anyone have any idea what's going on with this radio?
Old Apr 22, 2009 | 12:50 AM
BJ's SLK320's Avatar
2001 SLK320
I bought a 01 SLK320 in October and starting having this issue about two weeks after driving off the lot. I looked on all the different forums and talked with some guys at the local MB dealership. My issue was that there was something wrong with the internal wiring in the radio (probably because it was 8 yrs old). The easiest solution is to simply replace the radio. You can go buy an after-market head-unit that will fit the opening perfectly and will play MP3 Cds, about $200; or, you can spend about $800 and get a touchscreen unit with GPS. Your local Besy Buy can do the install in about an hour for less than $100.
If you don't like that idea, you can check out ebay for a replacement unit, but there is no guarantee that it will work.
Old Oct 19, 2010 | 11:19 AM
Miami-Michael's Avatar
2002 SLK 320
Having same problem
Hi -
I know this is an older post, but I've just started having the same problem on my 2002 SLK 320. I was curious as to what you finally ended up doing. Were you able to fix, or buy a new radio. If you replaced, what did you install?
Thanks -
Michael
