SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: slk transmition
Old Jan 9, 2010 | 03:48 PM
anddyboy's Avatar
slk 230
slk transmition
My gear stick will not always select from park I have to push a screwdriver down the hole to release the stick
What is the problem
Old Jan 10, 2010 | 01:12 PM
ajSvat's Avatar
ML63, VW Jetta, STI, Ducati Monster 1100
You may want to check to see if the brake light switch is working properly. Brake must be pressed in order to shift out of park so perhaps the switch sends the signal to the shifter lock. I would start there.
Old Jan 10, 2010 | 03:07 PM
anddyboy's Avatar
slk 230
thanks matey, this might tie in with ny abs/asb/esp light staying on, change it tommorow
Andy- Swansea
Old Jan 10, 2010 | 03:14 PM
ajSvat's Avatar
Yes sounds even more likely that the switch is the problem...Good Luck!
