SLK/R170: Engine not cranking..!
Key on “1”: SRS light is turning on for three seconds and turning off...
Key on “2”: All lights on, not the SRS light...
Trying to turn on: Not a click... Full silence only the radiator fan is turning full speed...
What might be the problem and of course the solution..?
The K40 relay seems OK and 15A fuses look normal...
Just two questions:
-the 40A fuse of the K40 relay... Is this shape is correct..? Or blown up..?
-the one circled in red on the K40 relay is it defective..?
If everything OK on this front what to look for next..?
Tried to move the car this morning...
A big “thump" and the transmission went into “limp mode”...
Took the car to an independent MB service...
Left engine mounting bloc was defective... Changed both...
Back home: WROOOOM and WROOOOM...
Life is beuatiful and even better with SLK...
Work: two hours... Cost: 303,- US dollars parts included...
