SLK/R170: Another Pulley Question
Thanks,
FD
The pre-2000 versions of the SLK230 with the supercharger clutch should have a different design which might allow a smaller pulley to be fitted - but I'm not 100% sure that this is indeed the case.
Renntech, ASP, Brabus, Vaeth, and Carlsson crankshaft pulleys all retain the harmonic damper (most are basically factory pulleys with a ring either press-fit or welded onto the factor pulley to increase the diameter. I'd go with a welded version to prevent any potential mishaps.
Cheers, BT
With the crankshaft solution it is very important to retain the orginal pulleyvdampeners as severe engine damage (crankshaft bearings and rods) can result from an inappropriate aftermarket pulley. ASP racing offers the welded solution, Carlsson, Väth and Kleeman use heavier screws to ensure pulley longevity. All these retain the OEM pulley by adding a pulley ring in increase diameter. I have a simple screw-on pulley ring which most tuners used then, works just fine since 3+ years.
I relocated the MAS on my pre-2000 model which eliminted that 3000 rpm hole. GIAC chip, larger intercooler (Vaeth) and Supersprint header/muffler are the other mods. I also replaced the (narrow) air box intake snorkel with a larger one.
Cheers, BT
The headers were installed before the intercooler got in.
I didn't notice much after installation of the header, maybe a bit more mid-range grunt but that's of course very subjective. Interestingly, if you can trust the water temp gauge, heat stress was significantly reduced. Before, temp was 85-90, after, it came down to 80 for most driving conditions.
On the other hand, the larger intercooler really helped performance, I guess primarily because of its much larger cross section compared to the OEM part = better air flow to engine. However, the header may now more effectively contribute, too, as more gas leaving the engine needs to be taken care of.
In any event, I hope to find a shop with a dyno soon so I can finally see the hp return on these many investments....
- FD
So headers that give 5% more power alone, will still give 5% more power with a pulley. But you've started, from a higher initial power output with the pulley, so there is a higher overall horsepower increase with headers if there is a pulley there.
Thanks for the header feedback, BT
What about the gearbox can it take the extra increase in HP?
I have an automtic in my SLK 230 komp -01 and I'm thinking of modify it further.
