SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: I need a HELP
Old Feb 19, 2011 | 01:03 PM
PARK JONGHYUK's Avatar
slk230k
Unhappy I need a HELP
I have owned 98 vehicles slk230 Year.
Sometimes symptoms do not start was gone.
Repaired again, but has experienced the same symptoms.
Vehicle after repairs after a car mechanic does not take the start at all.
Service center diagnosed the results are as follows.
ECU is not sending and receiving information together with the Key Box(signal receiver) I would say.
So, in the same Year of the vehicle and the ECU and the IFZ module, Key sought.
These parts are mounted on a vehicle, ignition on(turn on), but after you receive the same results as before.
It does not start and IFZ module is not recognize the signal.
Engineers to replace all of the startup line case does not work, but why not start
What is tricky.
What should I do? Please help
