SLK/R170: 2001 SLK320 Radiator Fan won't turn on
Hello!
My fan will not turn on so car gets hot with AC on. I have tested the fan , it works and replaced the fan control module. Not sure what to check next. The water level light is on but the system is full and window washer is full.
AC and heat work great. I do not have a wiring diagram to trace fan control wire or fuses/relays if used to run fan
Thanks all!
Thanks all!
