SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Fuel Filter?
Old Oct 21, 2012 | 12:13 PM
blueE430's Avatar
01 E430,99 SLK230
Fuel Filter?
Got a 99 SLK230 that my grandaughter drives most of the time. Today she most likely ran out of gas . A fellow came by and put some gas in it for her and she made it home and then it quit again. It starts but then stalls . Seems like fuel filter or line clogged. Am I correct on this? Car runs like new other than this. No other issues with car at any time before now. I am thinking that some gunk got in line because tank was empty and all it was picking up was the crap in the bottom of the tank and thusly the line is clogged. It will run a bit idling but soon stops when gas is used. Then restarts and problem arises . OK if I am close to correct where is the filter? IDK Thanks in advance for help
Old Nov 6, 2012 | 09:01 AM
dandb's Avatar
1999 slk roadster
Hello.
Filter is under car near right hand rear wheel, you will need ramp,pit, or simular it is coverd by black plastic cover three srews two easy one high up at rea,r you will need extension bar on socket.
