SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Please help.. SLK230 won't start, No crank
Old Nov 2, 2012 | 02:32 AM
kegrun's Avatar
slk230
Exclamation Please help.. SLK230 won't start, No crank
Hi, My Slk230 won't crank over at all? It had the same fault a couple of times but moving the selector in and out of park it would go again but now nothing? Appreciate your input...
Tried so far: New battery, reconditioned K40 relay, dismantled and cleaned ignition switch, removed and tested starter motor cleaned all battery leads just replaced the gear selector switch.
Cheers,
Old Nov 5, 2012 | 10:28 AM
dandb's Avatar
1999 slk roadster
Have you tried useing different key?Keys are coded and can play tricks with the security system.
Worth a try.
Old Nov 5, 2012 | 02:53 PM
kegrun's Avatar
slk230
Smile
Thanks for your post Dandb I bypassed everything and put a push start button on the centre console and it started (first time in a month of trying??) After giving it absolute death around the block it kinda backfired and blew out alot of carbon.. Since then it now starts with the key?? Hope it's sorted now but if it happens again all I have to do is push my pretty chrome button
Old Nov 5, 2012 | 06:40 PM
dandb's Avatar
1999 slk roadster
Glad its sorted {could be that key}
Enjoy.
