SLK/R170: P0410 is it related to the supercharger?
For the P0410 code, it could be either the air injection Shutoff valve or the Check Valve itself. It could be something that easy or a total clean up in the air injection vaccum lines. I have replaced a used shutoff valve i found in the part lot near my house at first and the CEL was erased, but I am still experiencing hesitations in cold starts. I have research it further about this problem and some people say it is a carbon build up in the check valve/shutoff valve which was true because my shutoff and check valves looked like they have a lot of build up and all black. Some also say the solution is to replace the check valve which I later did with a new one, but problem is, until now I am still experiencing the hesitation in the morning. Which is very bothersome since I have to wait at least two minutes to warm the car up in my open garage.
I just replaced the fuel filter and drained the trans fluid 8k miles ago.
I'm thinkg I may need to slap a new shutoff valve - which I havent done yet. But before I do, Im just really checking if it is the culprit.
Some related links below:
http://www.benzworld.org/forums/w203...ssor-w203.html
http://www.benzworld.org/forums/r170...-solution.html
