SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Oil Leak or bad mechanic?
Old Feb 11, 2014 | 08:43 PM
ecohen2's Avatar
Hi Folks,
A good friend of mine has an SLK230 Kompressor. After going to a Jiffy Lube and the local Mercedes dealer she noticed a bad smell coming from the car. My first thought was a bad oil filter or the drain plug had come loose.
I jacked the car up and noticed a very neat streak of differential oil from exactly where the cat ended all the way to where the muffler began. I also noticed oil along very specific pieces of plastic and the undercoating. None of it consistent with a bad seal, torn boot or anything else.
Has anyone else seen anything like this? Photos attached..
Thanks,
Ed
Attached Thumbnails Oil Leak or bad mechanic?-img_0201.jpg   Oil Leak or bad mechanic?-img_0206.jpg   Oil Leak or bad mechanic?-img_0207.jpg
