SLK/R170: Help for a new SLK owner
What point should I jack the car on when using a trolley Jack?
When I bought the car its stereo was missing, I replaced it with an expensive pioneer unit, I connected it all up using the head units speaker outputs, everthing works ok, but it sounds a bit, well, thin...not really bad but just not as good as I'd expect, is it just the standard speakers arent up to much? I was told that the car had amps as standar, but I couldnt see any line level connections for these if they existed, and connected up the speaker outputs as if they went straight to the speakers.
By the way its a 1999 230 Kompressor
Thanks in advance.
