SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: anyone with manual?
Old Mar 11, 2004 | 08:25 PM
midget fidger's Avatar
E550 Coupe
anyone with manual?
any of you have an SLK230 with the manual? do you like it? i saw somewhere that it wasn't all that great. i have a 98 CLK320 and want a manual instead
Old Mar 11, 2004 | 09:40 PM
Shaummy's Avatar
Hi,
I have a '02 SLK with the 6sp. tranny. I like it quite alot. Be prepared to be rowing the gears quite a bit, as the gear ratios are quite short until you get to about 3rd gear or so.
The clutch engagement could be a little more progressive for my taste, it's a little bit on the "it's on or it's off" mode for me.
I'd say try and find one and drive it if you can, there isn't a whole lot of foot room to be mashing all the pedals, but I'm 6' and 265lb and I can get the job done.
Hope that helps.
Later.
Old Mar 11, 2004 | 11:12 PM
mihaley's Avatar
i just recently got a 99 SLK230 manual (5-speed)
i like the clutch,but its taking me some time to get completly used to , it shifts very nicly after you get the hang of it
Old Mar 12, 2004 | 02:25 AM
Mik's Avatar
Mik
manual slk
I have the 6sp, and its not a great shifter. I had alot of problems with a too high tranny fluid level, causing the gears to not shift when cold. Now its fixed, but shifts still slower than other manuals I have owned.
Having that said I would get this car in manual again without thinking for a second. For me, even a ba shifter is still better than automatic (at least for a fun car).
-Mik
Old Mar 13, 2004 | 05:35 PM
adamrs80's Avatar
2004 SLK Special Edition
I have the 6-speed in my SLK and I had it in my coupe as well. It's a little tight when it's new but after about 5,000 miles I really think it feels much better. I had the same experience with my coupe so I don't think it's my imagination. It's not to best manual out there (S2000, Miata) but I think it will last for a long long time. Because they use the same transmission for the C320, and SLK320 I would think that it's a little less stressed in cars with the 2.3 or 1.8. Just my thoughts.
Old Mar 13, 2004 | 06:50 PM
Brian_R170's Avatar
'02 SLK32 AMG
I had a '99 SLK230 with 5-speed manual. Overall, I didn't like it. It was difficult to shift very fast. Both the clutch and the shifter were much less than ideal. I drove the 6-speed and it wasn't much better, plus you had to shift it more often.
Old Mar 16, 2004 | 06:04 PM
Supra's Avatar
CLK320 & SLK230
i agree with Brian_R170 , and the clutch is too long , pedals' position is not good , make me to have a hard time to do heel&toe .......
