SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Alarm and Locks Problem
Old Mar 30, 2004 | 11:04 PM
AnthonyR's Avatar
For about 3 weeks now I have this problem where while I am driving the car and out of nowhere the locks either lock or unlock. I am not sure if this is related but the alarm seems to go off at will. I cant leave the car for more than 3 hours without if going off it seems. If anyone has any idea or info on what the problem may be please post. I would appreciate it.
Old Mar 31, 2004 | 07:42 AM
DickB's Avatar
'99 SLK 230
There is a PSE module in the trunk which contains both a pneumatic pump for the locks and electronics to control stuff including the alarm. This area seems prone to moisture. My alarm was not working and it was due to moisture-related damage. The PSE was replaced under warranty. I'd check there first.
Old Jul 7, 2006 | 09:17 AM
kenandbj's Avatar
Alarm problem
On our SLK230 the alarm would sound after we locked the doors. I took your suggestion to check the PSE module. I opened up the module (the bottom pops off very easily) and found corrosion on the printed circuit board. I cleaned off the corrosion, reassembled the unit, reinstalled it and now it works fine.
Thank you for pointing me in that direction.
Ken
Old Jul 17, 2006 | 02:02 PM
DesignoSLK's Avatar
'07 SL55 AMG, '00/'04 SLK230 Designo Copper, '18 GMC Acadia Denali AWD
PSE Module
DickB, Where in the trunk is the module located? I have '00 230.
Thanks!
Old Jul 17, 2006 | 02:38 PM
E-Klasse's Avatar
W205 C300
It is just to the right of the spare tire. Pull the carpet liner up as if you were going to take out the spare. It sits in the bottom of the trunk.
Old Jul 17, 2006 | 03:44 PM
DesignoSLK's Avatar
PSE Location
Thanks E!
Old Jul 18, 2006 | 06:10 AM
bazzle's Avatar
PSE unit removal
http://www.benzworld.org/forums/r170...fit-check.html
Have a look here. I just removed and took some pix..
Bazzle
