SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Quick lowering/camber question.
Old Apr 1, 2004 | 07:59 PM
RedSLKChic's Avatar
I searched all over the boards and got a couple answers, but I need a final answer! I'm in the process of getting rims and springs for my car. First off, is Schatz a good brand or should I go with H&R? Also, with the drop (about 1.5") am I going to have an major problems with camber? If so, where can I get a correction kit? Last one, I am getting 19" wheels, from what I've seen on here, I need a 35-37mm offset in front with a max width of 8.5 and 30-37mm offset in the rear with a max width of 9.5. Would it be the end of the world if I didn't do a staggered setup? What would be the ideal tire/rim size setup with 19"s? THANK YOU!!
