SLK/R170: Code help - P0803 upshift solenoid circuit malfunction
Sometimes it feels like the fly-by-wire throttle is not opening as much as I am pressing down.... and a few times over the last 40k miles, it has hit the rev-limiter instead of shifting, so maybe the second code is really my problem... I did get fuel from a different place last time, I am going to fill up tomorrow from my normal place....
I had the codes read at autozone:
1: P0803 - upshift solenoid circuit malfunction
2: P0170 - Fuel trim malfunction (bank 1)
3: P0440 - Evaporative emissions control system malfunction
I did a search and only found the names of the codes at http://www.carsoftwares.com/mercedestroublecodes.html , which I already had from the scanner.
other cars call this a skip shift, or something like that, but I have never really noticed it ever skipping a gear.
If someone has the official manual on CD and can give me some pointers, it would be great... I would not mind spending money on a manual, I just want to know what I am getting for my money...
thanks,
mike c
Clearwater, FL
http://www.oldweakandpathetic.com/slk/
do a search the instructions for burning on a CD is here also....
electrical shift solenoid plate on top of valve body..... sounds like tranny removal??? hmmmm I just had the tranny out and apart in my '00 jeep wrangler this weekend, but that was a manual tranny.... I think I will research the CD a little before I decide to tackle this myself....
Sounds like from what I have been reading that I should just go ahead and put a new MAF sensor in becasue if it is not bad, it probably will be in the future??? (I did check for vacuum leaks with a can of brake cleaner and there was no indication of a leak)
#3 will tinker with the evap stuff in my spare time
-mike c
Clearwater, FL
