SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Newbie here searching. BAS/ASR solved with new fuse but now roof won't go down!!!
Old Jun 25, 2018 | 11:41 PM
firstrebel's Avatar
2001 SLK 230
Unhappy Newbie here searching. BAS/ASR solved with new fuse but now roof won't go down!!!
My left side tail light was out. When I changed it it still didn't work so I decided to switch it with the right side just to see if maybe it was a connection problem. In accessing those bulbs in the panels I must've hit something because I blew a fuse and all of the brake lights went out and the BAS/ASR light came on in the dash. I replaced the fuse and got the BAS/ASR off and the lights working again, all but the original top left tail light. I was going to be alright with that for awhile and felt pretty lucky that I'd fixed the fuse issue! Well my luck didn't last long because hours later I tried to let the top down and it got stuck just after the trunk opened. I can hear the motor running so that's not out, and I don't see any leaking. I haven't investigated thoroughly yet but I'm pretty sure that I must've just knocked something aside to set off that chain of events. Tomorrow I'm going to do a thorough look before I ask for a mechanics help. I'd appreciate any experiences. I've run across BAS/ASR problems simultaneous to roof problems but I'm still trying to find what to look for/what might be "off track".
Old Jul 4, 2018 | 01:11 PM
leapyfish's Avatar
2012 E350 75,xxx miles, 1998 SLK230 250,xxx miles
Here is a troubleshooting guide to help with your roof problem & this https://www.slkworld.com/r170/home.htm is a site that will show you where everything in your SLK is.
File Type: pdf
