SLK/R170: SLK 230 High Beam Issue
I have a 2001 SLK230 ... the high beams will not engage when the turn signal lever is pushed or pulled. I have looked through the wiring diagram for a relay.... without success.
Hoping someone can help.
Mark
I have had luck repairing these, others find replacing it suits them better. You can buy a used unit from any R170 or any chrysler crossfire (you do run the risk of getting another bad one).
IF you search the crossfire forum, you will find info on opening it up and repairing it.
hope that helps,
Chris
