K4 Power seat relay location
Subscribe
May 20, 2022 | 12:20 PM
Hi
Can anyone please explain the location of the K4 seat relay and what to remove to access.
It's RHD 2001 320
Is it somehow linked to the door switches and why?
Reply 0
Dec 2, 2022 | 03:00 PM
Are both of your seats immobile? There is some logic control over their operation which is alluded to in the owner's manual. If a relay fails, then I assume zero power goes to either seat. How certain are you the relay is causing this problem? When I got my car two years ago the drivers seat was immobile. Turned out to be failed wires from the fuse block. Each side has its own fuse. I ran a wire across the working passenger side and spliced in to the driver wiring under the carpet.
Reply 0
Dec 2, 2022 | 03:56 PM
I replaced the relay easy fix Both working fine.
Reply 0
Jul 4, 2024 | 01:24 PM
So where is the relay? have the same problem
Cheers, Mike
Reply 0
Subscribe
Currently Active Users (1)
