SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: https://youtu.be/BkeiWPxmHIM
Old Jun 2, 2022 | 03:39 AM
Billy22Bob's Avatar
R170 99SLK230 + SLK32
Blower Fan Brushes
Moderator - please delete this post ....it is a duplicate
Fan stopped - Finally I thought I had a problem with the resistor.....
Checked fuse - ok
Checked the signal from the switch = ok....
Put 12V across the blower terminals - starts up ok
Ordered bargain 25dollar Control resistor
Resistor arrived yesterday
Installed -
Problems....fan would always run - even without the key in the ignition!!!.....
Reading....
Seems like this isn't the first cheap controller to do this.....But....
In doing so I noticed the fan started working .....intermittently......
Found the wires plugging into the motor were dodgy....
Still couldnt control with the new resistor - but could with the old one - although patchy due to the plug
Gave the spade fits a bit of attention - however.....I cant get a solid and consistent connection
Too lazy to take the motor right out at this stage ....
QUESTION - If the brushes are worn do they connect directly onto these spade fits and hence
by jiggling the wires you can make or break the brush contact?
It would seem - I can get the wires in a subtle spot where the fan will work fine - but that will only last so long.
I guess I'll have to pull this fan right out and hopefully find some brushes - sources appreciated
changed subject
