SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: help! need to replace rotor
Old Dec 2, 2004 | 02:55 PM
snglbrd's Avatar
slk 230
slk 230 1998------I changed my front brake pads, and went to put on new rotors. I took off bolt to free rotor and then turned steering wheel to pull off Rotor... that didn't work, not enough room to slip off. Do I need to take off the two bolts behind caliper holder?? I tried and they are super tight... any help would be great thanks.
Old Dec 3, 2004 | 01:12 AM
cvayala's Avatar
2002 SLK32 AMG
I recently removed my rear rotor, and I do not think it possible to be removed without first removing the caliper.
Old Dec 3, 2004 | 09:27 AM
snglbrd's Avatar
slk 230
your right, thanks I will try some heat and penitrating oil
Old Dec 21, 2004 | 09:57 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
You shouldn't use penetrating oil. Just use some muscle and a larger wrench. They normally have thread locker on them.
-s-
