SLK/R170: under trunk drain spout?
2009 SLK 55 AMG
Hey guys, new to this forum so maybe question answered before. i have a 2002 320 and i noticed water dripping from a drain spout under the trunk below the spare tire well. what is this for? where does this water come from? we did have a thunderstorm the other night. no water in the trunk or spare tire wheel well.anyone, anyone? thanks
68 Datsun 2000 and 98 SLK230
Water draining from trunk
If you look at each side of your rear window, you will notice a hole with a grid over it, this is where the water is caught and sent down a drainpipe on each side of your vehicle.
Sometimes these tubes may be stopped up with debris. The grids will take care of the large stuff (leaves and things) but smaller material may pass through these grids and need to be cleaned out. A high-pressure air hose can usually get the water draining properly again.
Hope this helps,
Mike
Hope this helps,
Mike
