SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK200 w/o kompressor
Old 02-19-2005 | 07:18 PM
manciukas's Avatar
I have '99 SLK200 without kompressor and 100 kw it's a little bit boring.. I would like to install kompressor, but not sure that SLK200 and SLK200K engines ar the same (identical)? If they are, could I simply buy standart MB compressor and install it? I found some on eBay..
I'm very sorry for my english Thanks in advance!
Old 02-20-2005 | 02:11 AM
Brian_R170's Avatar
'02 SLK32 AMG
They are not the same engine. There were 2 different SLK200 Kompressor models. The pre-facelift version (built before March 2000) had approximately the same power output as the SLK230 Kompressor but they had a higher compression ratio and required higher octane fuel. The engine was strengthened compared to the SLK200 to handle the supercharger. This version was sold only in Italy, Spain, Greece, and a few other countries with very low sales volumes.
The post-facelift version (built after March 2000) has alot of small changes changes compared to pre-facelift SLK engines.
If you added a supercharger to your engine, you would need more than just the supercharger. You would also want the intercooler. Maybe some other stuff too.
Old 02-20-2005 | 04:06 AM
manciukas's Avatar
Thanks! Could you explain what differences are between SLK200 and SLK200K engines except that SLK200 are without kompressor? If I would install kompressor to a simple SLK200 what about engine lifetime then?
Quick Reply: SLK/R170: SLK200 w/o kompressor
