SLK/R171: Raising/Lowering All Windows?
2005 SLK350 - firemist red & beige interior
It finally stopped storming here this afternoon, the sun peeked out, so I pulled the new SLK350 out of the garage for the first time. The in-dash thermometer read 60, but with the top down the air scarf felt pretty good.
Here's my question: While driving with the top down, and the windows down, I wanted to see what the interior wind turbulence was like with all four windows up. I remember reading in the owner's manual (okay, sorry, yes, I did read through the manual ) that you can use the roof open/close switch on the console in quick double-pushes to raise or lower all windows. I wasn't ever able to pull off the correct sequence. I got the front windows to go up/down together using that sequence, but never figured out how to pull the rears along with the fronts. I double-checked the manual when I got home, and it seems like I'm doing what's written in the book.
What's the secret? Was I not rubbing my belly and my head at the same time I was pushing the switch? Any idea? Thanks.
...Karl (up to 48 miles on the odometer now)
2005 SLK350
Right... can't put all four up with top down, but can put all four windows down with top up. This is accomplished with a short tap down on the top switch, then holding it down until all windows are open. Kind of a tap-hold, if that makes sense.
