SLK/R171: Weird Electrical Problem
The problems started a few months ago with the car all of a sudden lowering the passenger window turning on the interior lights and then shouting at me cause the door was open it was however properly closed and if I opened and then closed the door the problem went away, then the traction control would activate for no reason whatsoever I could be doing a constant 60mph on a straight and dry road with no potholes and the TC would bring the car to a halt very violently about the same time my COMAND would reboot its self whenever it felt the need and would take over a minute to change a CD track these problems still continue.
Now yesterday again on a straight level and very flat road the car tells me its out of oil and to stop when I pulled into my office car park I checked for any oil leaking and found nothing so I left it for 30 mins and then used the press R 3 times trick to check the exact oil amount and it said 15.5L but the tank is not that big so I left it again for half an hour and tried again and it said 7.4L that seems like the correct reading to me however my headlights have decided that they are not needed and refuse to function and the windows will not fully close, does this sound like a computer fault to you guys as I plan on having the dealer recode every single module in the car to the latest software versions before I will accept it back.
Sorry about the long post and thanks in advance for any help
Dan
Thanks Dan
