SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: One Touch Automatic Roof
Old May 8, 2006 | 12:02 PM
Pigzmickey's Avatar
1998 SL 600 ///AMG. 1997 SL 320. 1999 SLK 230K. 2001 BMW R850.
I've worked it out, that if I can get 10 orders then I can sell them at just £299.00 each.
http://www.pigzmickey.pwp.blueyonder.co.uk/
Old May 8, 2006 | 12:47 PM
9moon's Avatar
SLK28
warrup there!! do we have that available here in los angeles??
Old May 8, 2006 | 03:39 PM
Pigzmickey's Avatar
Worldwide shipping available.
Old May 9, 2006 | 03:37 PM
etyu's Avatar
2008 SLK 55
Check out this thread: http://www.benzworld.org/forums/r171...mote-roof.html
You can order direct from Germany, and the service is excellent.
Old May 9, 2006 | 04:44 PM
9moon's Avatar
SLK28
uhmmm.. i aint orderin from germany..
Old May 10, 2006 | 01:04 AM
Ynot's Avatar
MBZ SLK
Y not? I ordered my rear lip spoiler and aerowings there, I recently just ordered the roof module and it should be here tomorrow or the day after.. woohoo...
Old May 10, 2006 | 11:04 AM
bloflin's Avatar
2005 SLK55 AMG
uhmmm.. i ain't orderin from germany..
uhmmmm, WHY ain't you? Where do you think you "ordered" your Mercedes from?
Old May 10, 2006 | 12:11 PM
9moon's Avatar
SLK28
.. by the way, is this ONE PUSH BOTTON coming in from a remote? i mean, how does it work? thru our remote??
Old May 10, 2006 | 04:09 PM
bakerdbl26's Avatar
SLK 350
I ordered mine from Germany, it took 5 days to receive it. I installed it about a week ago and it works fine. The module works by sensing the voltage your car emits when you lock or unlock the car.
To simplify, the roof module do not receive a signal from your remote. Your car's security system receives the rolling signal code then sends voltage to your vehicle locks. The roof module reads this voltage. The roof module will open or close the roof when you push the open or close button on your remote 3 times.
I ordered the module listed on the link by etyu. It cost less and is easer to install.
Old May 10, 2006 | 06:14 PM
xaveon's Avatar
2005 SL55
Aren't you selling it at 299 on that site right now? Ohh an for you guys in the US 299GBP is $555.00 USD.
Is there just one unit out there or a couple different units? Pigzmickey is selling a unit and bakerdbl26 purchased a unit, are they the same?
Pigzmickey, I didn't realize you were in the security space until I looked at your homepage. Check out http://www.xaveon.com or the online store at: http://www.xaveonsecurity.com
Also, what is the ordering process for these units? Do you have the install instructions available (maybe as a PDF)? Thanks!
Old May 10, 2006 | 06:33 PM
xaveon's Avatar
2005 SL55
Also, Pigzmickey what is the difference between your unit and this one? http://shop.piecha.com/catalog/produ...products_id=55
Thanks.
Old May 11, 2006 | 03:34 AM
Pigzmickey's Avatar
Thanks.
Honestly, not alot apart from price. They are cheaper! I always get a little worried with things that appear too cheap, but they have good feedback at present...
Old May 11, 2006 | 06:17 AM
-1-'s Avatar
-1-
SLK55///AMG The MONSTER on the block
This is an interesting product. I want to wait until several members have purchased, installed, and tested, to determine which product is the determined the best. Looking forward to additional input.
Old May 11, 2006 | 12:36 PM
Ynot's Avatar
MBZ SLK
I got mine yesterday and rushed the installation, got it all wrong. Will let you know when I get it right.
Old May 11, 2006 | 03:47 PM
9moon's Avatar
SLK28
u all seem like a good self auto-mechanic.. im afraid that if i purchase this item, i may not able to get it going..
Old May 11, 2006 | 04:42 PM
Vodil's Avatar
2006 SLK350
Just wait until www.MBenzNL.com starts to offer and and then you'll know its OK.
Old May 11, 2006 | 05:05 PM
bloflin's Avatar
2005 SLK55 AMG
baker, your are talking about he one from Marcus, right? Where did you find the information that it is sensing lock voltage? The only connection (besides power and gnd) is to the CANBUS. I believe it is a programmed microprocessor that is reading the status commands going across the CANBUS and then issues the appropriate commands. I don't believe there is any "voltage sensing" going on.
But I'm happy to be corrected/educated, as I am curious on the actual design. :roll eyes:
Old May 12, 2006 | 10:15 AM
bakerdbl26's Avatar
SLK 350
You are correct blofin,
I was putting it in a simple form so non tech people can understand. Rember, commands are carred by low voltage.
My point is the module do not receive a signal from your remote key. That is why the same module can be used in all the R171s.
Old May 12, 2006 | 11:23 AM
Ynot's Avatar
MBZ SLK
It's not that bad really, I got it to work last night. Anyone can do it, so far I love it, now I don't have to look like an idiot, standing on the side of my car holding the button and waiting for the roof to go down. I press the button 3x at a distance, walk up to my car, and off I go looking like, "BOND, JAMES BOND."
Old May 12, 2006 | 12:25 PM
9moon's Avatar
SLK28
what exactly is the name of the item again??
Old May 12, 2006 | 03:04 PM
Ynot's Avatar
MBZ SLK
Comfort varioroof module
http://shop.piecha.com/catalog/produ...08e50ce0b7287e
Old May 12, 2006 | 04:34 PM
9moon's Avatar
SLK28
... and how much is that in $ amount??
Old May 12, 2006 | 05:02 PM
Ynot's Avatar
MBZ SLK
I got it for $342, depends on the conversion rate of the Euro, could be a little bit more/less.
Old May 12, 2006 | 06:51 PM
bloflin's Avatar
2005 SLK55 AMG
I was putting it in a simple form so non tech people can understand. Rember, commands are carrd by low voltage.
Ok, but I don't want to confuse people either.
Most (all?) other aftermarket devices like this DID have to actually sense door lock solenoid power, among other signals, and then insert themself and apply timing signals/voltage to simulate a human doing things. It was very much a band-aid approach, though there are some good products. They didn't have a choice. In fact for some of them, on some car models, you actually had to have a spare key (or at least the security-chip) mounted in the car (under the dash), to get around the fact the ignition had to be at least in accessory mode. Other ones had to have a separate (additional) FOB and an additional RF receiver mounted in the car. All, in all, very messy.
My BELIEF, based on a my experience in "observing to reverse engineer" is:
We are lucky in that MB actually implemented a "remote" top control sequence (to support the optional IR key fob control, I suppose), EVEN though the IR FOB control is optional, the control sequence is programmed in all the cars. This means the control computer can control the top, even WITHOUT the key being in the ignition (obviates the need to have a key security chip mounted in the car).
Additionally, MB uses the CANBUS for all distributed functions, allows the installation of this part to be very simple. Again, for other vehicles, the installation typically required a number of wire attachments and wire cuts to different signals/controls.
The hard part was finding someone that understand the CANBUS command sequences (communication protocols and specific commands) to right the code to watch for commands routing thru the bus, and then to insert the command sequences needed.
I am VERY impressed with this product. It is well done (but again enabled by the "architecture" of the MB car control).
I believe it works like this:
FOB RF receiver (standard in the car) receives UNLOCK (or LOCK) from the FOB. The RF receiver generates the UNLOCK command sequence on the CANBUS. The standard door lock solenoid function sees the UNLOCK command on the BUS and energizes the door lock solenoid (and the lights to blink). Our NEW module also sees the UNLOCK command go by on the bus and starts counting. Then it sees a second one, then a third one (within a certain timeframe). It then inserts a command onto the CANBUS of Top Open that routes to the Convertible Top controller. Similar for LOCK.
The new module also monitors for a lock (or unlock) during the top cycle, and will issue a Top Stop command. It also monitors for a door key unlock or an ignition switch, etc.
Further, if it counts an additional 3 UNLOCKS, and it has seen a TOP DOWN COMPLETE Command Status, it then issues a WINDOWS DOWN command that the window controller receives.
For the button inside, not clear to me how that might work. Obviously the standard control requires the button to be held for 22 seconds. I would guess the button generates a Top Control Button Back (or Forward) repeatedly (or it is continuously sampled) and the standard Top Control will see the interruption if you let it go. Our module must see the 1 second hold, and generate the Top down command, and either block (capture) the button release so the standard control does not issue a Top Stop or it is able to tell the standard control it is not needed to control.
Finally the top down at speed, is similar, in that it interprets (or intercepts) the button push and issue the cycle, not allowing the standard control to be involved (as it would stop the cycle).
Then they also implemented a look for PHONE END and disable the module from CANBUS, as well as the speed limit setting function.
Again, all in all, very impressive and very clean.
Note: All of the above is my speculation , as I have absolutely NO knowledge of how MB CANBUS and control works.
If anyone knows better, please correct me, as I like to learn.
Old May 12, 2006 | 08:13 PM
xaveon's Avatar
2005 SL55
I ordered a unit from Marcus, yesterday and it was shipped today. I'll let you guys know how it goes. But from reading benzworld, it seems to be pretty easy and strait forward. As for which units are better, looking at how the system works, they're all the same.
