SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Close trunk partition error message
Old Sep 3, 2006 | 06:06 PM
oldman55's Avatar
06' SLK55 w/030 pack
Angry Close trunk partition error message
Tried to raise the roof and got close trunk oartition error message. Never had this problem in past. Anybody else ever get this error message? How do I clear this error message?
Old Sep 4, 2006 | 02:14 AM
benz--man's Avatar
'06 Red SLK350 & '01 Black ML320
I had this message several times when I tried to open the roof and forgot to close the boot separator, but as soon as I closed it everything worked fine and the message disappeared. Just be sure the separator is locked in place.
I hope is nothing else more serious that might require a visit to the dealear.
Old Sep 6, 2006 | 12:13 PM
slktyperice's Avatar
'12 C204 C250, '05 SLK350 (sold)
I think what old-man means is that when the roof is open, and you're trying to close it, it shows the message. It's happened to me a couple times when I'm carrying things that fit tightly under the lid, and some hard driving made the items dislodge the trunklid from its contact points. Just open the trunk and try to re-close the lid, and you'll be fine.
Old Sep 10, 2006 | 10:35 PM
Tooxzist's Avatar
Lightbulb
This error message came up for me. I couldn't put my top down. I knew that the seperator in the trunk (aka trunk partition) needs to be down to put the top down, however, mine was already down and I still got the error message.
Took it into the dealer and they said the trunk partition sensor went bad, needs to be ordered from Germany. Took a whole week!
However, it has now been a couple months after having it installed and no problems.
Old Aug 24, 2011 | 02:44 PM
benzy03's Avatar
SL 500
another solution
check to see that the wire connection underneath the right side trunk separator post is connected... mine was not and as soon as I plugged it back in the top worked normally No need to goto the mechanic
Old May 22, 2012 | 10:06 PM
GreazyDeigo's Avatar
2003 SL500
Been having this issue on and off for MONTHS. About to have my friend lock me in the trunk so I can poke and prod things until it works. Been to the dealer several times and have hundreds invested already and top still only works intermittently. I'll be following this thread and reply with any findings.
Old May 25, 2012 | 04:02 PM
2003 SL500
After being shut in my own trunk, here are my revelations:
The trunk gets HOT QUICKLY, don't put anything in there that needs to stay cold! It's also as small as it looks. I'm 5'4 and had to suck it in!
There is only 1 electrical relay that could possibly be related to the top. Standing outside the trunk looking in it's the plastic holder on the right, if you take it apart there's a small circuit board and a relay with 2 wires. I have not, however, fixed the issue of the top coming down so I think the assembly might have gone, taking it to a mechanic next week.
Old May 25, 2012 | 04:16 PM
fixer's Avatar
r 320cdi
I think you need to start with diagnostics, which may not help much. Just wanted to thank you for the chuckle you gave me about your observation about the trunk temperature. Hope you were not in there for too long.
Old May 25, 2012 | 06:53 PM
2003 SL500
Amazingly I zip-tied the broken arm in place and now the top works. Wonders... cease... hmmmm...
Old Jun 25, 2012 | 01:30 AM
2003 SL500
After SEVERAL trips to the mechanic, and a few THOUSAND dollars of GUESSING at the problem, I finally took my car to a new mechanic and am completely baffled at how the previous people are still in business.
Turns out in my car, perhaps in all our R230's, there is no computer code for "Convertible top pump is not responding/dead" so instead the display picks a random code for the trunk or top. This guy replaced the pump and for a week I have not had any problems whatsoever.
