SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: How to remove a Bluetooth puck
Old Nov 5, 2007 | 03:22 PM
joealbracht's Avatar
SLK350 & ML550
I recently got a ML550 with Bluetooth. What I'd like to do is temporarily remove the Bluetooth puck from the ML550 and connect it to the cables I have in my 2006 SLK350 center console to see if that alone allows Bluetooth to work in my SLK or not.
Never having seen the existing Bluetooth adapter before installation in the ML550, I can't figure out how to remove the adapter from the ML550. I know there is some form of clip on the bottom but I can't see it so I can't figure out how to disengage it. Anyone have any suggestions??
thanks
Old Nov 5, 2007 | 07:52 PM
-1-'s Avatar
-1-
SLK55///AMG The MONSTER on the block
I have it in my SLK 55. I've never attempted to remove. Check this link from another MB series vehicle. Maybe it will help.
http://www.slkworld.com/slk-r171-gen...prewiring.html
Old Nov 6, 2007 | 05:07 PM
SLK350 & ML550
-1-:
Yes, the link helped in understanding the various Bluetooth components but I still can't figure out how to "unclip" the existing Bluetooth puck from its adapter.
Thanks!
Old Nov 7, 2007 | 04:57 AM
alroumi's Avatar
G55, G500 & SLK55
Before doing this you should check if your SLK is pre-wired or not, and if its not pre-wired the dealer should add some connection cables so you can have the bluetooth kit working.
Old Nov 7, 2007 | 12:40 PM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
Originally Posted by joealbracht
-1-:
Thanks!
If you're looking at the puck, right around the MB symbol there is a black button you can press in...press this in and slide the puck out of the holder...may take you a few seconds to figure out which way it goes, but pressing the button "unclips" the puck, then you slide it out. As stated before, your SLK has to have the pre-wire in place for this to work. Let me know if you have any other questions.
Old Nov 7, 2007 | 01:15 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
thanks
You have a puck? As I understand the puck is the V60 and just unclips from cradle. The newer cars have what is called MHI and I think it is hard mounted. (screwed down)
BTW if you have a phone button your SLKs command it should be pre-wired
http://www.wireless4mb.com/
Old Apr 9, 2024 | 05:08 PM
ftdoc@joimail.c's Avatar
2007 GL450
HUGELY helpful! Thanks
When you submitted this pearl you probably had no idea it would still be helpful but it certainly was to me as I was stumped and had to get it out. BTW, it was still stubborn!
