SLK/R171: Renntech Airbox Internal View
1 Post
Sold - CLK500
Does anyone have a picture of the inside of a renntech airbox designed for the m113 motor?
I want to see it so i can copy the design to my stock airbox by dremelling out the restrictive baffles.
Thanks Mike
Thanks Mike
1 Post
GLK Matte Silver|MB Arts strut tower brace|MB Arts rear brace|Shaved door and bumper trim|K&N's|
I installed K&N's and cut out all the baffles and smoothed everything out in my GLK's airbox. You will feel the difference towards the upper RPMs and you will also hear a mild whistle at full throttle. The mod is very easy to do and if you have the tools, will only cost you your time.
1 Post
I just used a dremel. I did'nt take any pics, but when you open the airbox you will be removing any baffles you see. It is pretty easy and should take about 1-1.5 hours to complete. I went into the project blind with no info to help and was able to get it all cleared out, so I think anyone can do it if I can. LOL
Andy
1 Post
Quick tip I just remembered. When cutting the tabs off it is easiest to cut one side all the way through either the top side or the bottom side(the tab not the airbox)and then just apply pressure with your fingers on the side you cut. The tab should snap all the way off saving time from cutting the opposite side. All that should be left is minimal grinding for cleanup. I used a small diameter cutting drillbit that came with my Dremel. To smooth things out I used a tapered metal bit and did all the final shaving with that. Once you get all the trimming and shaving done just sand the plastic with fine sandpaper.
Disclaimer: This is in no way an instruction post it is just how it worked out for me.
CLK55 / E350 Coupe
Amazon
Anyone have any pics of the baffles you guys are refering too?
Renntech claims 5hp from standard AMG box. So cutting these baffles will result about the same Renntech gains or did they round off the box better?
1 Post
Sold - CLK500
i have decided not to proceed with this mod! I was down at rab motors where the service agent told me that a guy with an e55 put filters that were too small which allowed a piece of metal to get past the filters and go through the throttle body destroying the engine. unlike the 500 which has a maf with a screen to prevent such happening the e55 just has a throttle body.. the owner is now having to replace his whole motor costing in excess of 60k and all this is down to messing with the airbox..
im worried that if i was to dremel it out and a small piece of plastic was to go into the maf i could ruin my engine..
I have decided to go deep into my pockets and get kleemann headers and tune.. its gonna give me some real noticable performance and wont break the bank.
I want to dyno my car before the headers go in so i can report what the 500 makes when u add the kleemann headers..
does anyone know someone in the bay area with a dyno?? i dont want to fork out $100 just for a couple runs.
Mike
Mike
1 Post
When you Dremel the baffles out it is done off the vehicle. I just blew the plastic shavings out and then did a quick wipe down.
