SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Suspension question...
Old Aug 10, 2010 | 12:43 AM
The Godfather's Avatar
4 wheeled car.
I have a 2006 SLK 350 Sport. I'm about to slap some 19's on it. Anyone have any experience with lowering the SLK? I don't wanna do coilovers..well maybe, but I'm thinking just springs for now. Car has low miles so the shocks are like new.
Which springs give a proper and even drop? Thanks!
Mike
Old Aug 10, 2010 | 02:39 AM
Jochen's Avatar
2003 Dodge Ram 1500 SLT
Try Eibach springs...
As far as i know they have springs for the 350 they lowered the car for 1inch (front/rear).
If you wanna go lower i recommend a whole suspension system.
Old Aug 10, 2010 | 02:40 AM
4 wheeled car.
yeah I was thinking H&R or Eibach. Danke!
Old Aug 10, 2010 | 02:51 AM
Jochen's Avatar
You are welcome (Bitte ).
H&R is also not bad but Eibach is a bit better in my opinion.
May H&R have spings they lower your car for 1.4in.
But if you wanna put 19" on it may with 1in. lowering you do a better choose for the comfort...
Old Aug 22, 2010 | 02:33 PM
Ynot's Avatar
MBZ SLK
Here's my care on Brabus springs aka Eibach, with 19" wheels.
Old Aug 22, 2010 | 04:34 PM
4 wheeled car.
Hhhmmmm...Eibach isn't too bad at all. Looks pretty evenly dropped. I could go a tad lower though... we'll see...
Old Aug 23, 2010 | 12:07 PM
Ynot's Avatar
MBZ SLK
H&R then, another .3 or .4 inches lower.
Old Aug 29, 2010 | 08:47 AM
ben721364's Avatar
2010 E Class
What is your objective? Is it a lower look that you are after or is it to improve handling? If the latter, what will be the primary use of the lowered vehicle? In any case, you might want to talk with an experienced suspension engineer for best results. Messing with suspension geometry can be tricky.
Mike
Old Aug 29, 2010 | 09:33 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Coil overs is the way to go. You don't want to spend money on springs now only to spend more money later on coil overs.
Old Aug 29, 2010 | 11:18 AM
ben721364's Avatar
2010 E Class
It really depends on what his objective is. If 'low' is all he is after, shorter springs may be all that he needs.
Old Aug 31, 2010 | 09:15 AM
Ynot's Avatar
MBZ SLK
I've had lowering springs installed shortly after owning the SLK. It's been about 5 years now and still no problems. But I don't drive much ~13,000 miles
