SLK/R171: LONG ISLAND SPECIALS
Former Vendor of MBWorld
We are offering some specials at the shop right now.
We are offering a laser guided 4 wheel alignment special to you. We are one of the few shops that actually perform the correct alignment on this car, most alignment shops just set your steering wheel centered and your front toe so that the car goes straight and then send the car out. We do a complete 4 wheel alignment and check every part of your car. With these New York streets you will be amazed to see how far out of whack your alignment probably is. This is an easy way to improve your handling, give your tires good longevity and improve your satisfaction as a driver.
If you want to get an oil change while you are getting the alignment done we are offering that for $129.00. This will include an original equipment oil filter and synthetic oil. The oil change special is in conjunction with the alignment special.
We are also offering great savings on brake jobs and all other maintenance servicing. just give us a call for a price on the job and let us make yoru car 100% again.
Thanks-
-Craig
Thanks-
-Craig
