SLK/R171: Vario roof not working for Mercedes Benz SLK 300 (Model R171.454)
Car Model: Mercedes Benz SLK 300 (Model R171.454)
Problem: Vario roof not working.
Using a scan tool gives
DTC 9010: The supply voltage of the control unit is too low (undervoltage). The voltage was less tha 8.5V during 5sec;
9910: S118 (Tubular frame open limit switch), S119 (Tubular frame open limit switch): switching status not plausible Both directions might be operated;
9927: The Limit switch states indicate an invalid Vario roof position.
Using Data Monitoring mode, the following where displayed:
008: Rear left power window blocking not recognized
009: Rear Left power window position down not recognized
010: Rear left power window position up not recorgnized
033: Position and function of limit switch are OK the value state NO.
036: Vario roof position not defined
Channe no. 150 to 155 does not show any value
039: Locked end position not recognize.
142: Vario roof open not recognize
145: CAN front power window down: Not recognize
146: Luggaged compactement division not closed
148: Pump Temparature 40 degC (104 deg F) *
150: Hydraulic close.......
151 Hydraulic Open........
152: Backup transistor........
153: Solenoid Valve A7/5y1......
154: Actuation of hydraulic in close direction.......
155: Actuation of hydraulic in open direction........
* Please what is the expected Temparature
No problem the other way when opening. The Flap seems to have some sort of ratchet positions which I can hear when pushing the flap back. Is there some sort of adjustment to this. Thanks
