SLK/R171: 2006 slk55 transmission fluid change
Note: The AMG's (slk55) DO NOT have a torque converter drain plug. Make sure you measure the fluid you drained and add that back with 1 liter more. If you let it drain overnight or several days, you'll get about 0.5l more out. Overall, you should drain about 5-6 liters.
It reads a lot harder than it is.
